Loose antenna
Loose antenna
I just noticed yesterday that my antenna is loose. Not just the mast, but the whole base moves. I looked for some way to get to it. Looks like I'll have to remove the inner fender liner, unless someone knows an easier way.
I tried to but the screws just turn and don't tighten. I even tried applying a little upward pressure, and they still wouldn't tighten. I did shim it up a little with some white styrene plastic cut to the shape of the base. It's a little better but not tight. Looks like I'll have dive in and take the fender liner out.
I finally fixed the loose antenna. I removed the screws and took the base from the fender only to find someone did the old overtighten on the screws, pulled them through the sheet metal. Looked like 3 small volcanoes. I took a 1/8 inch punch and a small hammer and tapped the holes flat with the fender surface which in turn made the holes smaller. I reinstalled the base and screws, which required some force to get them back in because the holes were smaller. I tightened them just beyond snug. The antenna and base are now very secure, no more wiggle. It was a free fix, and free is good.
