98 Lowering Tips
Old 12-25-2003, 02:29 AM
Epd711
Epd711's Avatar
Default 98 Lowering Tips
I plan on lowering my 98 Mustang GT come spring time and was wondering whats a good set of springs, how much they cost, and where abouts i can purchase them (online). Thanks</P>
Epd711 is offline
Old 12-25-2003, 03:41 AM
hotrodman
I ♥ Acer
hotrodman's Avatar
.<edited><editID>hotrodman</editID><editDate>37986.5311342593</editDate></edited>
hotrodman is offline
Old 12-25-2003, 09:23 AM
tripsevn7
Moderating with Angels
tripsevn7's Avatar
i went with the tokico illumina suspension, springs and adjustables, with steeda caster camber plates . my 98 was sitting on 18x9 saleens with 275/35/18 on all four corners. looked mean and handled like a true sports car
tripsevn7 is offline
Old 12-25-2003, 12:47 PM
BLKSTANG9879
BLKSTANG9879's Avatar
Go with the Eibach Progressive rate springs. I got them and I'm very happy with them. You might want to think about getting the Steeda X2 ball joints to match the springs. If you don't in about a year you'll be replacing your stock ball joint.
BLKSTANG9879 is offline
Old 12-25-2003, 01:06 PM
mabguru
mabguru's Avatar
Lots of LA'ers in here yay! I got eibach prokits on 16 inchers you can look at my profile in the pics. I wish i had larger rims/bigger tires/or it was lower <IMG src=smileys/smiley8.gif border="0">. Well I also have a bolt on my x-pipe thats only a few inches off the ground, dragging road kill is not thrilling haha.<edited><editID>mabguru</editID><editDate>37980.4646412037</editDate></edited>
mabguru is offline
Old 12-25-2003, 06:33 PM
lpstang
lpstang's Avatar
my h-pipe hangs low without the springs so im affraid if i put springs on my carit will scrape bad!!!
lpstang is offline
Old 12-25-2003, 06:56 PM
BLKSTANG9879
Just do it. Worry about that if the problem occurs. You might just have to tighten the bolts on the h-pipe. I had to same problem.
Old 12-25-2003, 09:45 PM
lpstang
lpstang's Avatar
how hard is it to install springs????
lpstang is offline
Old 12-25-2003, 09:57 PM
BLKSTANG9879
Not to hard at all. But if you don't know what your doing you might what to get soemone who does. Because the springs are under alot of pressure, and if you don't take them off right it will come flying out, and cause you some serious injury.
Old 12-26-2003, 01:18 AM
hotrodman
I ♥ Acer
hotrodman's Avatar
.<edited><editID>hotrodman</editID><editDate>37986.5314236111</editDate></edited>
Quick Reply: 98 Lowering Tips
