Oil Cooler Adapter Gasket replacement.
I need to replace my O-Ring in my adapter gasket. I have a picture of the gasket i need to replace. I just have no clue how to get the "stud"/oil filter bolt out to take the adapter out. If anybody knows how to do this I would be great full for this advice.
The labeled part is the one I'm trying to replace
this, usually its a 14mm allen
i recommend if you are going that far, to replace the gasket behind the cooler as well... the one that goes between the block and cooler. pretty common leak/failure spot. you're going to lose a lot of coolant but its not a hard thing to replace.
picture of the one for reference
Mustang Videos
01-19-2016 01:37 PM
