2002 gt new rear end question
My mechanic says I need a new rear end which would entail about 50 parts and $5k. Is this about right? I have a thumping noise from the right side that increases with speed and is much more noticeable on left turns. I don't hear anything at under 20 MPH. It sounds like a tire is... delaminating... but apparently that is not the problem. The mechanized said the rear end is too loose to narrow down the problem. So... new differential, new axle bits... ideas? Comments? Random jokes?
LOL The only way a "rear end" would cost $5000 is if it covered much more than just an axle. For that price, I'd expect new control arms, shocks, rear wheels, brakes, brake cables, ABS sensors, bumper, trunk lid, spare tire, lights, fuel tank/pump/sending unit, oh and that tank better be FULL.
I don't disagree with the mechanic's assessment, only his price. He's got the upper hand here of actually having seen the car in person.
My first suspicion, like yours, is a bad tire. But it's also true that at nearly 15 years old, the axle could very well be in need of new bearings, which you might as well turn into a full rebuild with new seals and clutches. You can't really tell without opening it up if it's also going to need hard parts (axle-shafts, gears) replaced, so I'm sure he's trying to cover his a$$ by giving you an estimate to cover all the possibilities. But that estimate still sounds way too high, considering the relatively few things that could be causing a "thumping".
I'm really not sure what he means by "50 parts". I guess if you break it down, that's pretty close to the number of parts in a differential. He might just be trying to scare you into letting a pro handle it.
If it were me, I'd rotate the tires to see if the problem moves to a new area. And while the car's up in the air, check the axle for excessive play/runout.
I'd almost inclined to say that the mechanic either wants to make a home run,or he wants you to go away-he doesn't want to get involved with it.
How many miles on this car? No way that I'd drop 5k on an 02.(a few years ago,I dropped 3500 on a 02 Taurus,and very shortly another 1k....a mistake to get that invested in a high mileage ride.Something else always goes bad.
