97 Cobra Trans ?
97 Cobra Trans ?
I have alot of noise coming from the trans. I don't know if it is normal or not. I am having trouble going into reverse as well and 5th once in a great while. When i start off in frist you can hear the gears whine very loud. Please Help. thanks
RE: 97 Cobra Trans ?
there are 2 plugs on the passenger side of your tranny. open the top plug and stick your finger in it, you should feel some fluid if you move your finger towards the bottom a little.
how long has the shifter been installed, if the adjustment nuts arent set it can easily pop out gear or not want to go into gear, the noise is also likely coming from the shifter the stock shifter has a plastic-like shift arm and the Steeda has a billet shift arm causing a metal to metal contact on the shifter plate.
Matt's 95 Stang
10-05-2015 07:16 AM
