Help ASAP
Old 09-24-2017, 08:48 PM
Z28KLR
Z28KLR's Avatar
Post a pic of it. Use the black "new reply" button (not the "quick reply" box) and there is a paperclip icon that you can use to attach it in thumbnail format.
Z28KLR is offline
Old 09-25-2017, 02:09 PM
Krampus
Krampus's Avatar
Default Fuel pump and this vacuum line.
Now I'm thinking fuel pump because this is what my trunk looks like. It has this plug here and I actually found a fuel injection pressure tester kit in the trunk.
This is the small vacuum line I was talking about.
Krampus is offline
Old 09-25-2017, 03:44 PM
Z28KLR
Z28KLR's Avatar
Not positive but I believe that is the fuel pressure vacuum reference line (and I may be a hair off on the name too, lol). I'm thinkin a trip to your local hardware store should turn up a suitable replacement. Take a little piece in there with you if possible to match up the i.d. of the hose.
Z28KLR is offline
Old 09-25-2017, 06:01 PM
WJL
WJL's Avatar
You can clearly see a broken/ disconnected vacuum line in the picture, also I'm pretty sure the line with the red strip is the EVAP purge valve line. (Canister to Plenum)
WJL is offline
