2001 gt power window motor - MustangForums.com
Old 10-12-2017, 09:18 PM   #1
tadpole1969
tadpole1969's Avatar
Default 2001 gt power window motor
has anyone here ever replaced their window motor on drivers side? herd you can do it with out haveing to remove the Regulator Assembly, i changed the switch and no luck , passenger side window works so its not a fuse issue
tadpole1969 is offline   Reply With Quote
Old 10-13-2017, 03:21 PM   #2
Z28KLR
Z28KLR's Avatar
Super easy as long as the glass is up. Remove door panel, remove speaker, remove 3 nuts holding the motor in, reach in through speaker opening and it's yours.
If the glass is stuck down, different story. Still quite do-able, but it's a real bitch for sure. Involves unbolting the regulator assy from the door skin and getting it loose from the motor so you can get that out, then you gotta have someone hold the glass while you get the regulator lined back up so you can reattach it to the door.
Z28KLR is online now   Reply With Quote
Old 10-13-2017, 10:32 PM   #3
tadpole1969
thx yeah was pretty easy but my issue still remains, im getting power to switch and motor, i hooked the new motor up to switch connector before installing it and didnt activate it at all
Old 10-14-2017, 01:42 PM   #4
Z28KLR
Z28KLR's Avatar
You have confirmed 12V to the connector at the motor but it still doesn't work? Or you only have power to the switch but not past there?
You can test the motor by making a jumper wire and running it straight off the battery to the motor. I used some 16/3 Romex leftover from a house project and a couple alligator clips. Polarity is not important, changing polarity only reverses which direction the motor spins.
If you don't have power at the connector that clips on to the motor then you either have a bad switch (although it sounds like you already replaced that?) or wiring fault between switch and motor. Use a voltmeter to probe the terminals on the switch itself, verify the 12V coming in to it and out on each side (up and down positions). Or test the terminals for continuity when "closed", either way should confirm switch operation.
Old 10-14-2017, 07:20 PM   #5
tadpole1969
yeah got power to switch and motor, the old motor i took out still worked also took and hooked it to battery and spun up like it suppose to, only thing i havent done is checked the relay ,but one would think if passenger side is working then the relay is fine,but maybe im wrong dunno, im gonna check wireing at door inge tommorrow ,because when issue started if door was open the drivers window would not go up or down, but if closed it would
Old 10-15-2017, 01:06 PM   #6
Z28KLR
Z28KLR's Avatar
That last bit about window motor operation being dependent upon the door open or closed, to me anyway strongly suggests broken wire. Probably inside of or very near to the rubber conduit that carries the wiring between the door and chassis.
Just for fun, and because it will be easier to deal with I think, it may be worthwhile to confirm relay operation before tearing into that door... When you hit the switch to run that glass up or down, do you hear a faint click coming from in the dash somewhere? Everybody's car is different but on mine I can definitely hear the relay closing when I hit the switch. Since the passenger side works fine, find and swap the passenger side relay with the driver side. Sorry man I got no idea where those relays are at - they should be on or near the fuse panel, but they could be elsewhere under the dash.
Old 10-15-2017, 04:00 PM   #7
tadpole1969
yeah gonna check for broken wires this afternoon and th e relays
Old 10-16-2017, 06:45 PM   #8
tadpole1969
hey its a short in wireing at door hinge ! i pushed down on wireing while holding the switch down and wala it went to working so just got to trace it down and fix it now, seems like its shorting at the door or inside it just a little
Old 10-16-2017, 08:13 PM   #9
tadpole1969
found which wire was broke ! white with black stripe fixed, thx for your help! maybe i can return the favor one day
Old 10-17-2017, 01:36 AM   #10
Z28KLR
Z28KLR's Avatar
Nice, glad you were able to get it dealt with.
Featured Sponsors
