2000 GT Oil Sending Unit?
Im curious where it is? What it looks like? And if anyone has an idea of how to install it? I need to replace it this weekend, Im sure its not to terribly difficult. Thank you in advance for any help.
RE: 2000 GT Oil Sending Unit?
yeah a good set of channel lock pliers is all you should need. now when you put the new one in, I do reccomend buying a liquid RTV type thread sealer!! And crank it down tight so you can barely see any threads at all left
I just finished replacing mine, I tried the tape teflon and it leaked, so I bought a $4 tube of this thread sealer meant for senders, and I have had no leaks! $4 at lee auto parts
I have a 97 GT and I know we have different body styles but the engines haven't changed drastically, at least at the oil pressure sender.
Hope I helped some
George
Hope I helped some
George
Guest
Posts: n/a
ORIGINAL: monkeydude3
Hope I helped some
George
Hope I helped some
George
sweet... well I learned that the hard way. Only thing I lost was the cleanliness of a spot on my driveway. Had about a dozen tiny drips due to that being non sealed. Since using the rtv type sealant, no leaks. Also, if anyone adds an aftermarket oil pressure gauge be sure you do not over or under tighten the brass fittings. I had to do some tweaking because the owner before me installed them and didn't quite do it right.
I'm getting rid of my 94 explorer and now that I have this 97 Mustang GT I have a whole 'nother animal to learn from... technician in training here..
George
George
