Fan quit working. Ccrm and fan is new. Help
Old 05-04-2018, 07:14 AM
Jeremy Porter
Jeremy Porter's Avatar
Default Fan quit working. Ccrm and fan is new. Help
My fan quit working, last night I replaced the ccrm and the fan. The fuse 50amp is new as well. Directly hooked up the fan works great. I dont see or smell burned wires. I tested the volts on the ccrm as one thread said. The pins 1 and 2 have nothing but 12v on 3 and 4 and 6 and 7. Anyone have any ideas?
Jeremy Porter is offline
Old 05-04-2018, 10:29 AM
Urambo Tauro
Urambo Tauro's Avatar
Welcome!
What's the engine temperature when you're checking these pins for voltage?
Urambo Tauro is offline
Old 05-04-2018, 11:52 AM
Jeremy Porter
It was a hair hotter then it should have been. A.c. was also on max.
Old 05-04-2018, 01:07 PM
Urambo Tauro
Well I don't know what the differences are in CCRMs between years, but if your CCRM's pinouts are anything like on my '95, pins 1 & 2 are for LOW speed fan output, pins 3 & 4 are your 12V+ for the fan relays, and pins 6 & 7 are for HIGH speed fan output. (Hopefully someone can confirm this for whatever year your car is.)
If you're not getting low-speed fan voltage from the CCRM, you might have a bad CCRM, PCM or a wiring issue. But if your new fan isn't working at all, despite working great when directly hooked up to power, then you should probably check the ground circuit.
Old 05-04-2018, 01:28 PM
08'MustangDude
Banned
08'MustangDude's Avatar
Have you verified the relays are even working?
08'MustangDude is offline
Old 05-04-2018, 09:28 PM
Urambo Tauro
(That's what he was doing. He was checking for power at the pins for the "non-serviceable" relays that are integrated into the CCRM.)
Old 05-09-2018, 07:33 AM
Jeremy Porter
Default Relays are good.
I went ahead and tested my pins and 1 and 2 didn't show older got them, 3 and 4 had 12v and 6 and 7 didn't have anything. I took pin 46 on my pcm and grounded it out to a switch to bypass the ccrm and that didn't work. I had the ccrm replaced again and didn't work. The fan works fine hooked to power. Maybe my computer isn't working right?
Old 05-09-2018, 11:00 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Lets start from scratch. Where on this chart do you have/dont have power/ground?
WhiteFoxGT is offline
Old 05-09-2018, 11:31 AM
Jeremy Porter
I'll be home in about 8 hours I'll retest then and let you know. Thanks. Best diagram o have seen and not aware the 39 amp forget breaker fuse was apart of the cooling fan.
Old 05-09-2018, 06:32 PM
Jeremy Porter
not sure where to start? Fuse is good and has power to it. The fan hooked up to a 12v sourse works great. What's the best way to test these?
Quick Reply: Fan quit working. Ccrm and fan is new. Help
