Fan quit working. Ccrm and fan is new. Help
My fan quit working, last night I replaced the ccrm and the fan. The fuse 50amp is new as well. Directly hooked up the fan works great. I dont see or smell burned wires. I tested the volts on the ccrm as one thread said. The pins 1 and 2 have nothing but 12v on 3 and 4 and 6 and 7. Anyone have any ideas?
Well I don't know what the differences are in CCRMs between years, but if your CCRM's pinouts are anything like on my '95, pins 1 & 2 are for LOW speed fan output, pins 3 & 4 are your 12V+ for the fan relays, and pins 6 & 7 are for HIGH speed fan output. (Hopefully someone can confirm this for whatever year your car is.)
If you're not getting low-speed fan voltage from the CCRM, you might have a bad CCRM, PCM or a wiring issue. But if your new fan isn't working at all, despite working great when directly hooked up to power, then you should probably check the ground circuit.
Relays are good.
I went ahead and tested my pins and 1 and 2 didn't show older got them, 3 and 4 had 12v and 6 and 7 didn't have anything. I took pin 46 on my pcm and grounded it out to a switch to bypass the ccrm and that didn't work. I had the ccrm replaced again and didn't work. The fan works fine hooked to power. Maybe my computer isn't working right?
