Noisy Transmission after clutch change - MustangForums.com
Old 06-12-2018, 11:16 PM   #1
oblivion7986
oblivion7986's Avatar
Default Noisy Transmission after clutch change
I had changed the clutch, flywheel, pressure plate, and throwout bearing and ever since then ive had a rattling noise coming from the tranny when i let out the clutch. The noise stops completely when the clutch pedal is depressed but i cant quite pinpoint the source of the noise.. if anyone has some input on what it could be that would be great!
The noise started after i replaced the clutch and such.
oblivion7986 is offline   Reply With Quote
Old 06-13-2018, 06:46 AM   #2
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
well, id start with the obvious and check the clutch fork/throwout bearing. Pull the dust cover off the side and start the car. peek in thru that hole and look/listen for the culprit
WhiteFoxGT is offline   Reply With Quote
Old 06-13-2018, 06:48 AM   #3
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
could also be bearings/gear mesh inside the trans. when the clutch is depressed it allows the trans to stop spinning hence the noise going away. however without being there this is all just speculation
Noisy transmission after R & I, and squeak blkbeltolson 4.6L (1996-2004 Modular) Mustang 3 08-10-2012 02:32 PM
Noisy Lifters a week after roller rocker install. 1990boostang 5.0L (1979-1995) Mustang 7 06-28-2010 09:09 AM
Manual Transmission Noisy ??? Frank Bullitt V6 S197 General Discussion 5 07-10-2006 12:48 AM
noisy transmission Kaldar142 2005-2014 Mustangs 4 07-08-2006 09:55 AM
noisy transmission Erdrickk V6 S197 General Discussion 20 07-05-2006 10:59 PM
Featured Sponsors
