oil change
Old 12-28-2003, 03:55 PM
modie
modie's Avatar
Default oil change
Yeah this is a newbie question but does anyone have any suggestions on what all to check during an oil change? like air filters, tranmission and such? If it matters i have a 4.6 00' gt with about 22k miles. Thanks.
modie is offline
Old 12-28-2003, 04:08 PM
Glengemen
Glengemen's Avatar
Default oil change
Look in your owners manual for maint. intervals. If you feel like it, crawl under and make sure The rear end isn't leaking, as well as the transmission. If they dont leak, dont bother. On second thought, make sure they were filled from the factory, then change them as schedualled. After that if they don't leak, they are fine.</P>
Glengemen is offline
Old 12-28-2003, 04:10 PM
BlueStang225
BlueStang225's Avatar
Default oil change
man 22k is not much just change your oil and oil filter might wanna check your trans fluid if ya want see if it is dark or has metal flaks but it should not if it only has 22 i would change oil and filter but yeah check your book or take to dealership
BlueStang225 is offline
Old 12-28-2003, 08:00 PM
modie
modie's Avatar
Default oil change
Okay thanks.
modie is offline
Old 12-28-2003, 08:19 PM
BLKSTANG9879
BLKSTANG9879's Avatar
Default oil change
Go by the maintance sch. in the owners manual. The manuel knows best.
BLKSTANG9879 is offline
2007StangV6
01-28-2016 06:09 PM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: oil change
