help me put my stang into low 13s.
right now my car is stock...what all could i do to put it up to about 13.2-3 in a quarter....what bolt on mods and what gears and exhaust would put me at those numbers...its a 5 speed by the way.
RE: help me put my stang into low 13s.
Here is my list of mods I had on my GT. My advice to you is DONT GET NITTO DRAG RADIALS!
70mm Mac TB
85mm ProM MAM
Densecharger CAI
Steeda UD pulleys
Mac Ceramic Coated LT headers
Bassani O/R X pipe
Magnaflow Weld-in mufflers
Magnaflow 3.5” exhaust tips
Ported and Polished stock plenum
SCT Chip
H&R 1.5” progressive rate lowering springs
Monroe Sensatrac Fox body rear shocks
Blue Oval upper and lower control arms
FMS 4.10 gears
11” upgraded Ford racing clutch
Nitto 555R Drag Radials
Pro 5.0 Short throw shifter
Fan on/off switch
Mach 1 Grill Delete kit
Mach 1 Chin spoiler
My best runs were a 13.02 and 13.07 @ 105 mph. If you want to see the 12's then do all these mods and get some really stickey tires such as MT ET Drag radials or even ET Streets. Launch your car at 5000 or rev limiter and hand on for dear life! With these mods and some great tires, I pulled a 1.84 60'. The tires were to tall and taking to much of my gear out of my top end so I only pulled a 13.4 ET with them. If the tires had been the right size, then I would have been in the 12's for sure.
70mm Mac TB
85mm ProM MAM
Densecharger CAI
Steeda UD pulleys
Bassani O/R X pipe
SCT Chip
FMS 4.10 gears
Fan on/off switch
Mach 1 Chin spoiler
Well if I had it to do all over again this is the way I would have went...
Gears
Control arms
Tires
EXHAUST (LT headers, mid pipe or catback)
Shifter or CAI
These five mods helped me more than any of the others. Upper intake, IE Plenum, TB should be the very last thing you should do because its the most expensive mod for the amount of gain you will see.
Gears
Control arms
Tires
Shifter or CAI
