Weird stutter problem
Old 01-31-2019, 10:11 PM
  #21
Flash gt
Flash gt's Avatar
The oil pressure looks a little low also. My car the needle stays past the half way point.
Flash gt is offline
Old 02-02-2019, 10:30 AM
  #22
casual man mann
casual man mann's Avatar
I already cleaned and replaced the IAC during my weeks of troubleshooting so it is good. I believe the issue is related more to the automatic ECU trying to make adjustments to the IAC when it shouldn't, thus causing my weird drivability issues. Unplugging it caused it to run great except Idol is that about 1100 but that is fine by me.
and as far as the oil pressure gauge, from what I understand it's more of an on-off gauge and as long as it doesn't read 0 you have good pressure.
casual man mann is offline
Old 02-02-2019, 12:02 PM
  #23
Urambo Tauro
Urambo Tauro's Avatar
Originally Posted by casual man mann
...I just picked up a 96 gt 5 speed...
...I just checked the door tag and it's a factory manual. I'm also throwing a damn torque conver code...
...Just got it back from Firestone and it's a pcm from a Lincoln Town car...
Ok I have the right pcm on the way from rock auto with the correct calibration code. The eBay one I ordered just showed up and it isn't the right code but I tried it anyway since it's from the same car...
...Just took the new pcm from rock auto to ford and they flashed it, but the car won't run...​​​​​​
...I believe the issue is related more to the automatic ECU trying to make adjustments to the IAC when it shouldn't, thus causing my weird drivability issues...
Wait, are you still trying to run the car with an automatic PCM/ECU? What happened to the correct manual one?
Urambo Tauro is offline
Old 02-18-2019, 07:47 PM
  #24
casual man mann
Yes I was. The new correct ecu wouldn't run the car because it was missing the transceiver. But it's all good now!
Old 02-18-2019, 07:50 PM
  #25
casual man mann
Final update :
I went this morning to the junkyard and pulled the PATS module, transceiver from a 96. The codes didn't match up completely but i called Ford and they said it was compatible. They wouldn't cut me keys because the car is too old I guess. I just called a locksmith and he came and cut me 2 new keys and programmed for $150 and she runs!!!!
Haven't driven her yet but she's good to go. Thanks for the help guys.
Old 02-20-2019, 01:04 PM
  #26
Derf00
Gentleman's Relish
Derf00's Avatar
Thank you for the update. Glad to see it's running properly now.(?) Hopefully your experience and posting of the solution will help someone else in the future!
Derf00 is offline
yurizx6r
11-11-2016 11:19 AM
mirrormask
05-12-2016 01:09 PM
pelley
07-10-2010 03:49 AM
Deadweight70
12-01-2009 11:30 PM
Riceinator
07-14-2008 07:46 AM
Quick Reply: Weird stutter problem
