How to drain fuel tank - fuel pump issue
Old 04-14-2019, 07:37 AM
crazyone64
Default How to drain fuel tank - fuel pump issue
Hi
My baby, 2003 mach 1, 80,000km, died while driving. Scenario was fuel deprivation. Towed it home on the flatbed. $160 sigh.
Realized the fuel pump is not priming.
I've got 3/4 tank full and I am wondering how to empty the fuel tank considering the fuel pump is not functioning, the car will not start and I don't believe 2003 allows siphon techniques.
crazyone64 is offline
Old 04-14-2019, 07:40 AM
crazyone64
Background - the car was stored for the winter, drove it 5 km, parked, on the way back home it died.
First time this happened.
Don't think it's related but last year I changed the starter, it cranks np.
Old 04-16-2019, 06:41 PM
08'MustangDude
There are many ways to drain the tank. Some older cars even had drain plugs in them,
so you can drain the fuel into a container from underneath...
The right way:
Other ways:
Hand pump.... Many vehicles will also have a small metal door or flap that may prevent the tubing from being fed into the tank.
If that is the case, use your screwdriver to push the small metal door open, and then proceed to feed the tubing down into the tank.
You can replace the pump with the fuel in it, you just have to be careful!
I the pump doesn't prime, but will run, you can use the pump to drain the tank.
If you jumper the +12V connector to the fuel pump test line, then you will turn on the pump continuously until you pull the jumper wire.
08'MustangDude is online now
5POINTOH
03-26-2018 02:29 AM
clawlan
03-15-2011 06:13 PM
FLMustangMan
02-19-2011 08:40 AM
Timetravelinn
09-23-2008 06:32 PM
Quick Reply: How to drain fuel tank - fuel pump issue
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
