Tinting tailights?
RE: Tinting tailights?
IS this the only vendor that sells the film?
http://www.autobadges.com/vinyldecals/
www.ninosport.com has them too. Other than that, havent seen them anywhere else.
what would look best with performance red paint, smoked or blacked out? http://home.ec.rr.com/dlazrael/mustanggt.htm
I've used the tester tint spray before. it works but doesn't hold up. after about 8months and 2 weeks of over 100degree heat, it cracked and peeled off.
i just wiped it down again and resprayed.
but this time i sprayed the inside of the housing instead of the outside. it takes a long time because you have to spray a little then let it dry, then repeat but holds up much better then spraying the outside.
