Caster Camber Plates
RE: Caster Camber Plates
how much are you lowered.
they say there is enought adjustment in the stock suspention to do up to a 1 3/4" drop. I don't know the shop i worked at didn't do lowered cars. if it is 2" you will need the caster camber plates. and see if you can find a shop that has a life time warrenty on alighments (then you can go in every 10k miles or so and have them reset every thing.
ORIGINAL: LazrRd00GT
What are the benefits or c/c plates; also, will buying them help reduce uneven tire wear? And where do i go to get them properly adjusted and aligned?
99-04 Mustangs suck **** in the tracking department, meaning they follow every rut in the road. That's because the center point of the strut plate (caster) is almost directly above the control arm instead of at an angle. Ever wonder why your car seems to never track straight on a bumpy road? That's why.
If the car can't be aligned to spec without the CC plates then yes, they will help with uneven tire wear. You may want to look at a better alignment shop too to see if maybe your current shop just doesn't know what they're doing.
Okay I have seen CC plates at teamshinoda.com and because my 96 stang came with Boss Shinoda decals I was really interested in their CC plates. But, it sounds like I would need to do some suspension mods like maybee........tokico struts and eibach springs, then get the CC plates for them to make a handling difference. Is that right?
ORIGINAL: mosnet23
