Stainless Steel Inserts
Hey I got my Stainless Steel Inserts yesterday and I didn't get any instructions with them, I know one said has paper on the letters but thats the good side. How do you stick these things on your bumper, yes I got them though Mustangtuning.com, do they always make mistakes like this?
RE: Stainless Steel Inserts
No instructions or adhesive for me when I ordered them from mustangtuning.
Everyone take note: If you plan on getting stainless steel inserts for your stang, don't get them from mustangtuning!
You will need to go out and buy some 3m double sided moulding tape... it's black and hard to work with. You'll have to cut it to fit all around your lettering, somtimes cutting strips in half length-wise making it tough. Just sit down and spend a couple hours with it and wash the area before applying them. It's slow and tedious, thanks mustangtuning!
I got the same ones. I was going to return them and buy new ones but I decided not to. You have to rip off one side of the 3M tape and stick that to the side that does NOT have the label covering the letter. Then you put them on you car. It's simple.
They are simple to install and much better than the vinyl letters. Just make sure you use a towel or something soft to press them on when you get them positioned. It is likely that Mustangtuning buys them from SS Inserts.
ORIGINAL: pitch
09-24-2015 09:18 PM
09-10-2015 08:39 PM
