No one knows the answer!
Pull up a chair and grab a soda, this may take a while. I am the owner of a 2001 Mustang Gt. Mods include Steeda G-Trac suspension, caster camber plates, Tokico shocks, Aluminum rear control arms, underdrive pullies, throttle body spacer, C&L Cold air plenum, 80 mm MAF and filter. Motor is basically stock. My problem is a surging sensation that takes places while driving. Hard acceleration, mild acceleration, highway cruising, if feels as if your sitting in a rocking chair. Have had injectors cleaned, installed new plugs, compression checked, diagnostics run!
No codes, no fuel/air ratio problems, no apparent miss. Ford dealer says they are no prepared to deal with modded stangs!!!! WAS wondering if anyone else might be experiencing the same problems.
RE: No one knows the answer!
I was having that kinda problem when I installed my accufab upper intake plenum and throttle body, and Mac straight shot cold air intake. I unistalled and reinstalled my upper plenum so many times. That it eventaully went away. But check your vaccum lines that corrospond to your intake plenum and cold air intake.
If the 'surging sensation' happens when you push hard on the right pedal, that is normal!
Seriously though, I've never heard of this. My only ideas are:
Check the voltage on your TPS. I don't have the info in front of me for the TPS, but plenty of folks here can help you with that.
The IAC could be fouled, expecially if you run 93 octane in the car. Take if off and clean with carb cleaner if necessary. Granted, this should NOT be the problem, but it can't hurt to look.
ORIGINAL: 04BlueGT
I would suggest like above checking the TPS, or IAC. If you have not had your car tuned, I'd run 87 in it. I have to run 93 or better in my car now, cuz it's been tuned for it, but beforehand I ran 87. I tried 93 for 6mths when it was stock & brand new. I eventually developed hard starts & a rougher idle. I went to 87 one day I was on 'E' & immediately my car started & idled smoother. Now however...nothing less than 93.
ORIGINAL: JD1969
Not to pick on you, but 93 octane WILL NOT do this, I am however interested in why you say this. This might sound funny but try rotating the MAF, somtimes when a CAI is instaled the airflow hits the MAF funny and causes it to misread, I've never seen cause a surge at all RPM's, mostly during idle, but it's worht a shot.
ORIGINAL: 04BlueGT
ORIGINAL: 04BlueGT
The car is set up to run 87. Running 93 can cause deposits to build up in the intake and IAC (or so says my mech). Like I said, I seriously doubt that this is the issue here. The car is not nearly old enough.
ORIGINAL: JD1969
ORIGINAL: 04BlueGT
ORIGINAL: ibeeskeef
sounds like plugs and plug wires. I know you changed the plugs, did you change the wires as well?
ORIGINAL: yello1stang
If this doesn't work, check your air filter for holes. Finally make sure to check your fuel filter. Sometime sensors can just go, your O2 or MAF sensor could be faulty but 99.9% of the time they would throw a code.
