HELP removing aftermarket hood
hey everyone i got myself a 96 gt. i purchased this car with the whole cervinis stalker kit on it and now i want to take the ram air hood off so i can apply mesh grill in air duct openings. now what is the best way to take the hood off? is it as easy as taking the 1 bolt from both the left and right sides or where the hinge is and removing all 3 bolts from each side of the hood?? i would assume the 1 bolt from each side would be the easiest but will i run into any problems do this... any suggestions welcomed
RE: HELP removing aftermarket hood
For removing the stock hood, you need to have it up and have someone help you. The stock hood also has some wiring that you need to remove also. Not sure about the Cervinis hood but I'm assuming its the same way.
jwog666
12-27-2021 08:09 PM
09-24-2015 09:18 PM
