70mm vs. 75mm Accufab?
Old 11-23-2005, 03:59 AM
4ZZS
4ZZS's Avatar
Default 70mm vs. 75mm Accufab?
I am ready to order a C&L intake kit with the 85mm MAF, TrueFlow intake pipe and a matching Accufab throttle body and plenum. My question is about the throttle body size.
I had someone at Mustang Tuning tell me that for a non-turbo or supercharged engine that I should NOT go larger than 70mm. He said that there is actually a minor loss of performance by going from a 70mm to the 75mm UNLESS you are forcing air into the engine with a turbo or supercharger.
I'm looking for an experienced reply to that.
There is only about a $10 difference, so that's no big deal. I would just like to know which size will perform better and resell better.
Thanks.
4ZZS is offline
Old 11-23-2005, 04:36 AM
Voodoo
Voodoo's Avatar
Default RE: 70mm vs. 75mm Accufab?
I have seen the flow charts for the throttle body size and the info you got from Mustang Tuning sounds accurate. Do a search for throttle body flow and you should find it.
Voodoo is offline
Old 11-23-2005, 10:34 AM
Chopper
Chopper's Avatar
MM&FF did a test using both sizes and the 75mm won out by a couple of horses.I have a 75mm set-up and it makes me happy.The 70mm is probably adequate with a stock engine but if you plan on upgrading heads,cams,or exhaust later on you might want to go with a bigger set-up.Since there's no penalty to go bigger right now,why not?
Chopper is offline
Old 11-23-2005, 01:34 PM
pj1010
pj1010's Avatar
ORIGINAL: Chopper
That is his question. Someone informed him that there IS a penalty.
pj1010 is offline
Old 11-23-2005, 01:49 PM
Dave2000GT
Dave2000GT's Avatar
ORIGINAL: Chopper
Maybe the 75mm won out by a couple of PEAK horses... but what about the rest of the rpm range ? I would suspect that it would lose out especially on the lower rpm power... peak power is read in to far too much.
Dave2000GT is offline
Old 11-23-2005, 02:42 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
mm&ff usually talk about avg. HP somewhere in almost all of their articles. you should look at those numbers.
redass02gt is offline
Old 11-23-2005, 02:55 PM
Deannostang
Deannostang's Avatar
All I have heard and read previously is if you use an Accufab plenum, you only need to use a 70mm throttle body. If you use another aftermarket plenum such as C&L and a few others out there, it is recommended to go with the 75mm. That seems to be the overall opinion in the Mustang world.
Deannostang is offline
Old 11-24-2005, 02:04 AM
4ZZS
4ZZS's Avatar
Some people have been suggesting I wait with the intake system until later. Would I get more bang from a new intake system or switching the stock H-pipe to a catted X-pipe?
4ZZS is offline
Old 11-24-2005, 02:37 AM
bb1211
bb1211's Avatar
i just put on a 75 bbk TB and a c&l plenum, and after a tune picked up 9rwhp and 7 rwtq. the throttle response is much better, and you can definetly feel the power at higher rpm's.
bb1211 is offline
Old 11-24-2005, 03:45 AM
JonBeast
Moderator
JonBeast's Avatar
75mm setups are better for F1
70mm for N/A
I just put on a BBK 70mm TB and a C&L Plenum...I've happy with the throttle response/ power gains.
JonBeast is offline
Quick Reply: 70mm vs. 75mm Accufab?
