How to minimize rear body roll?
What's a good way to minimize the body roll in the rear end. I just installed a Tokico Illumina Adv. Handling kit w/springs, Mac Lower control arms, MM CC-Plates and MM subframe connectors. It is alot better but it still seems like the rear rolls more than I like while cornering. Would a stronger anti sway bar help? Don't get me wrong, I have not even gone fast enough around a corner to even have a bit of under or over steer. I don't know but it may be better to have the rear roll as it does but still seems like it's too much.
RE: How to minimize rear body roll?
shock tower brace for the rear? I didn't even know they made those. I wouldn't do that though because it sounds like you would have to remove the moulding from the trunk for good. Who makes the best sway bar for the rear?
which ever brand you like best. everybody uses the same basic design. the only difference is the thickness. so pick the size thats best suited for waht you want. if you get a really thick one itll allow you to oversteer much more easaly
Luke9222
10-22-2015 11:55 PM
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
