Which is Better?
Which is Better?
This one is the Maximum motorsports:
1).MM Caster/Camber Plates
MM Full Length Subframe Connectors
MM Drag Race Adjustable Rear Lower Control Arms
Tokico Illumina Drag Struts
Tokico Illumina Shocks
H&R Sport Springs
Ford Racing Perf. Parts Rear Upper Control Arms
2).Steeda Caster/Camber Plates
lakewood 70/30 and 50/50 shocks and struts
Eibach drag launch
Steeda alum. upper and lower control arms.
H&R Sport Springs
Eibach drag launch
RE: Which is Better?
Griggsracing and maximum motorsports are mainly focused on road racing, but they do sell set-ups for drag racing but both are expensive. In my opinion I rate griggsracing #1, maximum motorsports #2, and steeda #3. But that is regards to road racing. If you want just drag racing I think aftermarket upper and lower control arms, new springs and shocks and struts, subframe connectors, caster camber plates, and a bumpsteer kit will be all you need.
But if you want better you can go to a 5 link setup which steeda sells, or you can go to a 3 link rear setup which MM and griggs both sell. I have not used either but I plan on setting my car up with griggs racing suspension. So you have three different rear suspension geometrys to choose from. The factory 4 link, steeda's 5 link or MM and Griggsracing 3 link.
