wrecked da stang =(
RE: wrecked da stang =(
first thing that came to my mind when I read the post "Teenager + New Supercharger= Wrecked Mustang" Sorry, just learn from it, it could have been alot worse, suck it up and buy some used tires, I had a blow out in the middle of nowhere off of I75 once and some a-hole tried to charged me 75, but if you are around your hometown you shouldn't pay more than 20 for a tire.
ORIGINAL: wpaskar
All four of your rims are the exact same? As in, putting a rear rim on a front wheel won't matter?
yep, but my left side rims are in good shape, so if i take both of the rims ont he left and put em on the front and my new rims on the back, i should be ok. the ones on the right are just about trashed. theres a small chunk knocked out of one and its lip is pretty bent.
Kind of ironic in the other thread about you talking how you're a safe driver and you're worried about the other idiots on the road.
Alignment problem, yep maybe a little; but if it pulls that hard to right when you're going 50 with your hands on the wheel the cars clearly not safe to drive.
did you get alignment after your spring install?
what mustang_montana said...drifters buy the old shop tires cause they are near bald...but there might be some ok ones if you look hard enough.
finding used tires in 315 size might be hard and worth calling around your local shops if you must have that size
ORIGINAL: ZW99GT
Damnit dude that sucks!!!!1 Where were you when you hit the curb?
well... its driveable now... i was on oldstage road when i did it.... tall *** 4" curb....
then today when i was crusing looking for a couple runs after kar kare i found a civic si supercharged and we were pretty damn close and i was only going up to 5lbs of boost. i cant romp on it till i get my tune. bad thing is a cop saw us do it and im alittle worried that he may have my tag right now... that would suck. i also ran a s2000 that revved up at me and it was a total ownage at 4lbs.
ORIGINAL: mustangman02232
cheap 315 series tires, good luck on that one,
cheapest i found so far is 210 and that is for some summito's.... are they any good?
