exhaust question
exhaust question
Is it possible to install the muffler tailpipe assemblys on a 00 gt in your driveway or do you need to get the car up on a hoist . That big axle bend looks like it could cause some problems manouevering it through. not a big deal just like to save a few bucks when i can .thanx
RE: exhaust question
You can always use jack stands, but I used my buddy's lift. If you drop your reard end everything will slide right through. That's what we did. Jack the car's *** up high enough that when we dropped the rear end there was plenty of room.
ORIGINAL: nanaki
just cut the old one off
i cut my whole stock v6 **** off with a hacksaw, it sucked hardcore....
i cut my y to make ready for true dual exhaust....it is kinda tricky getting that old muffler-to-tailpipe assembly thing off...i just cut before the assembly right after the muffler and then twisted that mfer all around and got it out....im spending a little less than 300 for some lead pipes,magnaflow mufflers,and some tail pipes installed tomorrow...so i saved a little bit, i think.....im not sure it was worth the manual labor with my dull as$ hacksaw tho...lol
good luck
ORIGINAL: nanaki
sawzall!!!
sawzall!!!
yup. makes life soooo much easier. A hacksaw would take FOREVER.
It does take a bit of maneuvering to get the new pipes over and around the axle but it can be done without too much trouble.
Don't tighten everything up as you go. Wait until you are done the whole system to position everything properly, then go back and tighten it all up.
re-tighten everything after a week or so.
ORIGINAL: MikeHawke
ORIGINAL: p0rsche23
Yeah, if ur a ******.....come on be a man get out there with ur hacksaw and cut that crap off! It will make you feel so manly when ur done,LoL..
ORIGINAL: MikeHawke
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
kawiguy827
09-01-2015 07:09 PM
