dynoed the stang today!
#51
RE: dynoed the stang today!
ORIGINAL: mcmmotorsports
Did you ever find it strange that our numbers (both PSI and HP) are lower than the V2's?
I wish I would've known this before. I may not have been stressing so much recently about my low #'s
#52
No, I do not have a T/B or Plenum
All of my mods are listed on my website:
http://www.mcmmotorsports.com
Click on the Mustang Link.
Haven't updated my sig here yet.
#53
I notice the lighting airmass. Isn't that a 90mm? Some guys may say I'm wrong but the guy from the dyno I work with says that to big a airmass does not necessary help. And what are the numbers on the fuelpump? 255lph?
#54
I dyno'd 347hp with a 3.3 pulley with no cooler and no IAT sensor after the blower.I put the IAT sensor and a cooler on and got over 400hp. If you don't have an IAT after the blower the car really can't be tuned to it's full potential with or without a cooler because the tuner can only guess what to set the timing. I was told that a 3.6 and a 3.3 pulley would make close to the same hp without a cooler because you would have to retard timing with the extra boost making that extra boost detrimental. The cooler and IAT added 60 hp. The V1 is less efficient and will create more heat also decreasing overall HP. Get a cooler if you don't have one. I know they are expensive and I was pissed that I had to get one but I'm glad I did.
#55
#57
ORIGINAL: trbuddy
And by the way, really nice looking car!
ORIGINAL: trbuddy
#58
Thank you
This is the EXACT same setup that is sold through Modular Powerhouse as a Mongoose kit. It has been proven.
ORIGINAL: trbuddy
ORIGINAL: trbuddy
#59
Thank you
ORIGINAL: trbuddy
ORIGINAL: trbuddy
Anyway, looking at your mods I didn't see headers. Oversight or just not yet? Odd that your not getting more boost with the smaller pulley. Maybe the belt is slipping some?
#60
Absoultely NO belt slip. No headers either, probably won't see them or I may, just not 100% sure yet.
Found out that the pulley I need is a 3.2, 3.48 is what came standard on the V-1's.
I will see my 10psi, I AM SURE OF IT.
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
