Shift Kit for auto 04 GT
Old 12-17-2005, 12:44 PM
romancer
romancer's Avatar
Default Shift Kit for auto 04 GT
Anyone here have experience with shift kits with their 99+ gts?
I was looking to get a shift kit this winter...
Thanks.
romancer is offline
Old 12-17-2005, 02:26 PM
Voodoo
Voodoo's Avatar
Default RE: Shift Kit for auto 04 GT
Why don't you just get a hand held tuner. The shift firmness can be adjusted firm enough that I even soften it up at part throttle because it's too firm. I have both the Diablo sport predator and the SCT X-Cal 2. I have my custom tune done with the X-Cal 2 because that's the software my tuner uses for dyno tunes but I'm not totally sure if it's completely done with testing since it's a new product. I do like the Predator also but the X-Cal 2 has more adjustability with shift points. The only thing is you have to make the changes on your desktop and upload the tune to the X-Cal 2 before you then put the tune in the car. Don't bother with any kind of shift kit unless you need a new trans or your trans is broke and it needs work. A handheld tuner is a must with an automatic trans. The shift firmness stock is so weak that even with a completely stock Mustang the trans will slip dramatically at wide open causing more wear on the trans.
http://www.diablosport.com/main.php
http://www.sctflash.com/xc2.php
Voodoo is offline
Old 12-17-2005, 03:50 PM
mustangman02232
mustangman02232's Avatar
ORIGINAL: Voodoo
^^^easiest way,
go to transgo if you want a shift kit, but i would just get a tuner.
mustangman02232 is offline
carid
07-08-2016 09:55 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Mustangmalo
09-06-2015 05:22 PM
09-01-2015 08:16 PM
Quick Reply: Shift Kit for auto 04 GT
