saleen rims
RE: saleen rims
I'm currently running 18x9 up front and 18x10 in the rear. But, I think I'll be going to iForged Aero's (18x9 front and 18x10.5 Rear) in either gunmetal or anthracite come summer.
Tires are Pirelli P-Zero Rosso's (255/35ZR18 in the front and 295/35ZR18 in the rear).
I also recommend BFG's or Nitto's. My car doesn't get driven much, so I'm not too concerned with excessive wear. If you drive it a lot, the Nitto's don't seem to wear as fast as the BFG DR's.
RE: saleen rims
Strongly agreed! Go with 255-265 in the front and 295 or larger in the rear. Like everyone said BFG's and Nittos are good rubbers too...
ORIGINAL: TMG
i think either set would look bad ***.
RE: saleen rims
It seems if you get the authentic Saleen 18x10 wheels, you'll have rubbing issues going larger than 295 due to the offset. I have heard the knock-off Saleen 18x10's have a slightly different offset and will handle 305 and even 315's in the rear with no issues of rubbing.
Just giving you heads up...and why I haven't gone wider than a 295 tire yet.
ORIGINAL: xx9gt6xx
ORIGINAL: TMG
RE: saleen rims
I have saleen knockoffs on front and rear 18x9's. I should have gotten 18x10's on ther rear and will do that in the future. I fan some BFG's to start and they are used, but grab well. I have also heard lots of good things about the Toyo's Proxes T1R's.
Two sites that have had the best prices i have seen are:
http://www.discounttiredirect.com/direct/home.do
http://performanceplustire.com/
mungodrums
09-28-2015 10:54 PM
