Timing - Diablo Predator
RE: Timing - Diablo Predator
ORIGINAL: ROB 98GT
i just came back from a drive and i advanced all the way in both ranges. the car felt stronger. after that i datalogged it for 20 mins. i noticed the spark degrees goes from about 19 to 42 degrees while i'm driving. not sure what that means. when i went to the diablosport web site it says to datalog without the tune to get the spark degrees and then after the tune is in to see what your factory degrees of timing is. i'm kinda confused on makeing how to knock the degrees back for my nitrous tune if theres a 10 degree difference while the diablo tune advanced is in the car. i didn't data log on the stock tune yet because i got pulled over because i looked "suspecious" while i was looking at the tuner in the car.
damn you tha man!!! when i maxed out the spark advance it did feel quite a bit faster. when i first got the predater i noticed a diiference but not too much. thanks for all your info you have given me the last couple months, i appreciate it. later.
i just got 7hp for christmas yahhhhhhhhh!
ORIGINAL: dan
lol my new setup is.. every time i go to the track i take out my tuner and retard my timing all the way, so i can spray.. then when im done i advance it all the way back lol.
ORIGINAL: Voodoo
What time did you get at the track wit the nitrous? Did you ever have the car put on a dyno? You could probably get quite a bit more HP both ways if you had a tuner tweak it with the NX a and without. You would have to find a tuner that uses Diablo sport software though.
ORIGINAL: dan
ORIGINAL: 66_mustang_04
with all my mods i hit 12.4 at 110 with a 100 shot with bald bfgs
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
