Can the T45 be removed from a 96 GT without removing the bellhousing or clutch cable and such?
I'm trying to figure out how high I need raise the vehicle to get it out.
Jack the vehicle up as high as you can get it. You have to take it out with the bellhousing on it. You will have to drop the exhaust, take off the starter, take out the shifter, driveshaft, unhook clutch cable, speedometer cable, unbolt the bellhousing from engine, and remove the crossmember.
