Cheap HP mods for a 4.6... i found one
i always hear newbies asking about mods that are free/cheap mods for mustangs well i have found one. an up grade from a stock 4.6 TB(65mm) to a sock 5.4TN (70mm) should be good for about 8HP. i found a used 5.4 Upper Plunum, TB and TPS Sensor, on ebay for $30 shiped. i think $30 for a 70mm is better then a aftermarket 70mm for $200. just thought i would let you guys know.
RE: Cheap HP mods for a 4.6... i found one
well i was going to put it on today at school, but i didn't bring the 5.4 gasket(its like a 1/8th inche spacer that has a ruber seal around it, reusable) but eveything looks like it will just go right on. it looks the same just a little bigger.
ok so i installed the 5.4L 70mm tb today and it fits awsome and runs great. so this is a cheap mod for a 4.6 later ill post pistures of them so you guys can see the difrences in them.
holy crap thats awesome!! what model year and vehicles have this throttle body?? what all do you need? plenum,tb,and gasket?? details details. also did you notice a difference in power??
i installed my CIA at the sme time, ya it is a little not a low but im not sure, together its like 10hp or so. i got the the TB off ebay from a PI 5.4 so probably would be good it came with a gasket, it is like a 1/8th inche spacer with a rubber seal. the 5.4 plenum wont work it has a diff shape and you can use a 70mm tb on a stock upper plenum with on mods to it. so a cheap mod to paying $200 for a 70mm or 75mm tb and $38 for a TPS
