exhaust question
i was wondering when buying exhaust for a 2001 cobra should i buy new converters or will the stock ones work ok.
RE: exhaust question
Well if your going to buy shorty headers than you can use the stock mid-pipe. If you buy midlength or longtubes you need to replace the midpipe with an aftermarket one. IF your just buying a cat-back exhaust, you can use the stock mid-pipe.
i was planing on bbk long tubes with the bbk o/r x pipe and mac cat back exhaust. i can buy the x pipe with converters or without them. i was just wondering if the stock ones would be fine or if i should buy knews.
Yes you need to replace the cats, you cant take them off. The only way you could is if your cut them out and had them welded in a new x-pipe. but the stock mid-pipe has four cats, it would just make more sense to buy the high flow cats. The diameter of the piping is about a 1/2" larger and the cats are high flow, so you will see a better performance gain from this. Plus you probably wont save any money if you got an off-road pipe and put your old cats on it. Unless you did the welding yourself, but you wouldnt gain as much power with that setup.
depending on where he lives, there is the option of buying an o/r pipe and saving himself a few dollars,, hundred at least i would say
let us know what you decide on, or if youve got any more questions |
i have a 2000 gt and have an offroad x pipe on it and also i have it lowered and from me pulling up on driveways it scraps and i was under the car the other week and i saw there were big dents at the top of the x pipe what should i do to prevent that is there an x pipe i can buy that i can put closer to the floor
i would not use cat's at all. i fitted my 01 cobra with bbk longtubes, bbk h pipe and the slp loudmouth 2 caback system. u could not ask for a better sounding mustang.
Thanks,,,,,,,hotrod11us |
