NEED ADVICE
NEED ADVICE
NEED ADVICE. I wanted to get some opinions on what I’m thinking about doing to my 2000 Saleen. I have a Vortech Supercharger with out the after cooler.
Well here goes:
Forged Internals
Supercharger Cams
Professional Product’sTyphoon intake manifold (Ported)
42 lb injectors
Long tube headers
90mm MAF
75mm throttle body
Custom tune
I plan on running about 12lbs of boost after all is done.
Does this sound like it will work well?
How much horse power can I expect to the wheels?
Thanks any info is appreciated!!!
Well here goes:
Forged Internals
Supercharger Cams
42 lb injectors
Long tube headers
90mm MAF
75mm throttle body
Custom tune
RE: NEED ADVICE
Get an intercooler. And run all the boost u want. If you run 12, then you can see 450rwhp all day long. Why did you forge your engine only to run safe power for a non forged engine??????
RE: NEED ADVICE
ORIGINAL: Saleen2000
If I go any higher with out an after cooler couldn’t that cause detonation or heat soak not exactly sure on the terms. I’m kind of new to all this.
Thanks
Thanks
RE: NEED ADVICE
ORIGINAL: Slick97gt
with all those bolts on and 12 psi i could see you making close to 500 rwhp.
Omgitsa88Stang
10-05-2015 07:33 AM
