thinking of engine swap
ive got a 96 gt wut should i know, need,if i want to put a 450 hp 351 under the hood .
the gt has a susp. kit 355 gears the rest of the stuff i have done is to the motor but there are alot of miles on it 130K
the 351 is a ho motor with port and polished heads duel 4bbl set of cams crank ete.....
besides a stronger sway bar what else should i be lookn to upgrade ?thank you
RE: thinking of engine swap
Your gonna have to find out if it will bolt up to your k-member, you might have a to get a new one. Why are you gonna go with a 351? Its a bigger motor so you have to make more power because the wieght. Also if you go with the 351 I would go with fuel injection. You already have the 351?
