Does anybody know....
Where I can find instructions on how to re-wire my tail lights so that all 3 light up when I apply the brakes instead of just the two inside lights on each side...?
RE: Does anybody know....
Don't know how to do that, but i switch my in-side lights with the middle ones so that the middle ones on each side don't light up just to be different i only seen one other sn95 like it it. looks bad A$$ when braking. Has an aggressive look.
ORIGINAL: Emann0007
Anybody else wanna post something that's not an answer my question???
that is for sequential lights, maybe something useful is in there on what lights up/when?
This is for 99+ stangs and I'm not sure if it'll work but here you go. http://www.miracerros.com/mustang/brake.htm
ORIGINAL: sickspeedgt
take it to someone who knows how to do it
ok, here you go emann. Try this. Go get some wire strippers/cutters and some electricians tape of your color preference.
find the wire of the light that doesnt light up. found it yet?ok , good.We will call this wire #1. take it and cut it about 6 in back. Now strip off some plastic so the there is about 3/4 of an inch of bare wire. now, find the wire to a light that DOES light up. Found it? ok good.We will call this wire #2. cut a section of the rubber off wire #2 (be careful not to damage the wire). Now you can connect the end of bare wire #1 to the middle of bare wire #2. Get some of your electricians tape and tape off all the bare wires from #1 & #2. And you are done!
You will simpily be sending the voltage of wire #2 to wire #1. When light #2 lights up, so will light #1.
Check out this detailed step by step foolproof set of instructions @....................
http://www.thefreeimagehosting.com/U...0taillight.bmp
you may have to open it up in paint or something else cuz it didnt transfer well.
