TB & Plenum
RE: TB & Plenum
get a upper plenum for like 200 or whatever and get a 70mm tb off a PI 5.4L F-150 for less then $30 off ebay and it probably will cpme with the TPS which a new one is like $30 and they are lamos impossable to get off with out breaking
RE: TB & Plenum
ORIGINAL: Dark_Horse
RE: TB & Plenum
I believe 15rwhp is very easy to come about with this setup. I know most of you have heard of JLT intakes. Those are dyno proven to give anywhere from 8rwhp to 12rwhp. Add a 70mm t/b and plenum to that and you'll get about 20rwhp.
RE: TB & Plenum
ORIGINAL: nanaki
that 12RWHP was probably with the combination of the tb/plenum and full exhaust. most CAIs will only net you like 6-8 at most.
RE: TB & Plenum
http://216.119.83.47/dynoresults.php
Here is dyno sheets with the JLT intake.
Some are done stock, some have exhaust
Notice some show 10hp gains over other intakes
RE: TB & Plenum
ORIGINAL: sprostang
From what ive read, the accufab plenum and c&l tb will give you the most.
C&L plenum an dthe 75mm Accufab give are 1-2 Hp differnece from the full accufab set-up. But if you have ever looked at the C&L you can see where the difference is. The C&L is a rough cast inside and that willgenerate turbulance and decrease the HP. I took the time to port and polish the C&L and I think it is just as good as the car I drove with the full accufab.
But then again who can fell 1-2hp?
