I just posted a Thread on here and you guys helped me out alot with my gears and I figured out I had a bad plug wire set so its def pushing a little more power now but i'm in need of advice. Before I had the rear end done I was getting vibrations and clunking from the rear end and I figured the fluid was in need of changing so I jsut had the gears done and I got the master bearing kit also, so everything is new in that direction but now the car is doing it again but only after its driven like 12+ miles then when you turn you get almost like a grabbing in the tires when you turn def not smooth and you get vibration, it was doing this b4 the gears so i know its not that for sure. I used the royal puple fluid so I didnt have to add any friction modifier but what do I do now is it the POSI unit if so where do I get a cheap one this car is tapping me out.
U- Joints even tho it doesnt do it until you drive it quite a bit I had them look at them when they put the gears in mechanic said they were original but ok?
