I need help modding my 03 GT
Hello guys, I´m new around here, I need some help, I´m the proud owner of a 03 GT, I have added somethings into my car like :
-AEM Bruteforce Intake
-AIRAID POWERAID Throttle Body Spacer
-HYPERTECH Power Programmer III
-12,000K HID´s Kit
-BFgoodrich G-Force KDW tires
-Brake pads
As you can see I just started, probably for most of you around here this mods are nothing but I think is a good start, I was thinking about adding a Magnaflow Exhaust system and BBK headers, what do you think? should I do something different? I was thinking about maybe save some money and add a procharger stage 2 or maybe a Turbo, I really need help with this, or probably I should be doing something else.
Thanks! hope to see you guys around!
-12,000K HID´s Kit
-Brake pads
RE: I need help modding my 03 GT
It's nice, but you will need the supporting mods, plus if you want to run the kind of boost it produces (10psi is the max, some people run with 12 but it's a huge risk), you will need to rebuild your bottom end with some forged internals.
ORIGINAL: pLaGuIeNtO
-12,000K HID´s Kit
-Brake pads
-12,000K HID´s Kit
-Brake pads
an04COBRA Date 1/8/2006 5:33:39 PM
ORIGINAL: rbstang
[/quote]
Thanks Rbstang, I want to do everything as it should so I can make my GT runs faster, I think I will definetely go for the Procharger, what I would like to know is wich mods I have to do so my car can support that, what should I add or mod before getting the Procharger?
Dan04COBRA Date 1/8/2006 6:02:45 PM
You can install the Procharger with the mods you have now, but you will make significantly less HP than say you had other bolt-ons combined with the Procharger.
-Procharger stage II 8psi with the mods I have right now :
-Procharger stage II 8psi with the mods I need to make it release the maximum HP without destroying my engine :
-Procharger stage II 10psi with the mods I have right now :
-Procharger stage II 10psi with the mods I need to make it release the maximum HP without destroying my engine :
How much money would you recommend me or think is enough to make my car run perfectly without any problem using the procharger? please forgive me for making so many questions but I think that´s the best way to learn and what better way to learn than from someone who has more knowledge about this like you guys, thanks!
It's hard to guess. With the mods you have now (nothing for power really) you will get over the 300RWHP mark.
Figure full bolt-ons plus 10PSI, you will be over 400RWHP and over 400RWTQ.
There is absolutely nothing wrong with asking questions, a lot of people come here with questions or presume they already know the answer and when we suggest otherwise, they get defensive!! Ask away!!!
