nitrous or headers!
got some cash to spend...should i go with nitrous 100 shot or long tubes?
RE: nitrous or headers!
Nitrous.
You need to chill with all these 4.6 threads 13secGT...JEEEZ
Anyway.....nitrous |
what all would i need to buy to have a safe and good nitrous setup.....bottle warmer the n20 kit, etc.....what all exactly would i have to have.....what brand also?
want quick easy power? nitrous
want a reliable car and will add more bolt ons? headers |
Can't tell you which brand, because I would be a hypocrit since I don't have nitrous.
Bottle warmer will keep bottle pressure up and ensure you get the true shot you are jetted for. A window switch is a great idea, you'll never be in the wrong gear and spray at 2,000 rpms in 4th gear on accident and make your motor very unhappy. You won't have to worry about bouncing off your limiter and buying yourself a Huffy because your motor is in 1,000 pieces. Those are the 2 things I highly suggest you have. Ideally, a wet setup is your safest bet, but a dry shot under 100 is also perfectly fine. |
sorry bout the posts....but if i get the nitrous kit what else would i need to havea safe and good setup...do i need diffferent spark plugs or anything like that? bottle warmer, etc.
You will need a colder plug, look at my post above ^
what exactly is the window switch? so i would need window switch, the kit, bottle warmer, and colder plugs.....what bout gauges or anything like that?
The window switch will automaticly spray the nitrous when you are in the set RPM range.
