MGW shifter install
01-10-2006, 11:35 PM
MGW shifter install
Ok I just got my shifter in today and I was looking at the instructions and it looks like I need 2 get under the car 2 install the short throw shifter, is this correct???
01-10-2006, 11:36 PM
RE: MGW shifter install
No you dont need to get under the car at all. you can do everything in your car.
01-10-2006, 11:46 PM
all u have to do is pull the boot off then un bolt the handle then the base and pull it right off. its the easiest install ever and u can do it at night time with the dome light its so easy
01-10-2006, 11:47 PM
unless you have an 05, everything can be done from the drivers seat. Unless you want to change your fluid while your at it.
01-10-2006, 11:51 PM
nope. no need. I sat in the drivers seat the whole time.
01-11-2006, 12:48 AM
Yeah, thats just to change the fluid.
01-11-2006, 05:37 AM
whats underneath the car that you could possibly need to get to? when that dust boot comes off you can see straight to the ground
01-11-2006, 07:42 AM
Quote:
ORIGINAL: tcuallstar
The transmission drain plug, if your changing the tranny fluid while doing the swap.
01-11-2006, 08:44 AM
http://www.stangpro.com/html/articles/mgwshifter.htm
You only need to get under the car to change the fluid if you do so when you change the shifter.
Other then that just sit in the drivers seat.
01-11-2006, 11:03 AM
sorry to sway from the subject, but all you guys with your cars in the avatar and sig looks awesome.
but to contribute to the thread, the shifter can all be done from inside the car.
mtgldr
02-03-2024 09:00 PM
carid
07-08-2016 09:55 AM
robjh22
Suspension
09-08-2015 12:47 PM
vintageaion
09-08-2015 10:45 AM
Webster454
09-07-2015 04:59 AM
2002 ,
2003 ,
98 ,
ground ,
gt ,
install ,
installing ,
mgw ,
mustang ,
shifter ,
shipping ,
time
