What is everything completely i would need to run a vortech v2 supercharger on my 2000 gt?
I was thinking about buying a vortech v2 supercharger someone has forsale getting a pretty good deal on it to make it work completely what all would i need i mean everything down to the last bolt and fitting? any help would be appreciated!
RE: What is everything completely i would need to run a vortech v2 supercharger on my 2000 gt?
The kit should come with pretty much everything you need. It also depends on what boost you are running. To play it safe and make it worth the install, I would do the following.
Injectors & upgraded fuel pump (as the kit probably doesn't come with either)
Boost gauge & A/F ratio gauge
Custom chip with Dyno tune to make sure everything is turning right
which V2 is it? is it aftercooled? what pulley is on it? how much ya gonna get it for? how many miles on it.
u will need:
gauges for safety
42 lb injectors and lightning maf
atleast a 255lph fuel pump
maybe a better clutch
a custom chip with a tune on a dyno (i used a flip chip)
much better tires for traction (not a need but u will want em!!)
maybe also a couple pieces of lines and you will also need a tap for the oil pan.. that thing was a bitch to find! its NPT thread.
u will need:
gauges for safety
ORIGINAL: racer02GTstang
u will need:
gauges for safety
u will need:
gauges for safety
ORIGINAL: code3GT
Anderson Power Pipe.
u will need:
gauges for safety
u will need:
gauges for safety
The guy just told me v2 but im thinking it's the v2 sq not the superquiet though which i would rather have! Mileage unknow, it's un intercooled but if i get it i plan on intercooling it eventually. That's the powerpipe i also plan on going with! I will be paying $1500 for the kit. Guy says i will need to buy injectors, maf, and a tune so im hoping everything else is there all hoses and fittings also have to buy a bracket! need a different one than he has. Gotta ask him if he has a fmu and pump? I think this covers about everthing i will need doesn't it? I know if i can get this im going to start working on a stroker shortblock from dss or livernois and do heads, cams, and intake next!
I don't like my AFM power pipe. The damn bung for the bypass is right in the way so I can't turn the thing the way I want. I also had to weld another bung on for the second bypass for the cooler.
SQ mean super quiet... and its not really quiet.. its still got a loud whistle at idle and everyone is like "whys your car whistling??!!!?!". its pretty funny actually.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Soldier GT
08-12-2015 03:46 PM
