cat back?
RE: cat back?
Unless he bought just the mufflers.... If thats the case you can take it to a muffler shop and your pipes from the cats back rerun and the mufflers put in.. its jus the type of bending they do crimps the pipe quite a bit so you dont get the full flow.. a 3" pipe might be crimped as far as 1 3/4" in some spots. Your better off buying a full catback system for that reason.. if you did buy just mufflers, I would return them. The cat back system is only gonna run you a couple hundred more.
09-01-2015 08:16 PM
