2000 gt starting problem after sitting
RE: 2000 gt starting problem after sitting
So your saying your starter isnt working? If so, your starter relay may be bad. That would be relay #4 in the power distribution box under the hood. Check that . Or possible the starter is bad itself.
well i jsut tried gonig to parts source and canadian tire and no luck with the dry gas, also i looked at the relay and well i cant really tell anything but they all looked fine, i went under the car tapped the starter while cranking except nothing, but then i could hear the pssshhh noise ven greater (when i was under)
