Is the stock clutch cable adjustable?
RE: Is the stock clutch cable adjustable?
As far as I know you pull up on the pedal and it adjusts itself. Not sure if it applies to your year though, or if I am even correct... Sorry, a bit tired. But this is better than nothing.
Yeah just pull up and then push it all the way back in slow and hold it for a few sec. I didnt tell any difference when i tried when i had the stock cable, supposively it is suppose to click if it adjusted there was an adjustment. But I didnt hear a click either.
Im a little confused by what you guys mean, and am extremely curious myself. I would LOVE to adjust the pedal so that it grabs lower to the floor!
on certain model years idk which ones, if you pull up on the clutch pedal with your hand until it stops, then push it all the way to the floor till it clicks, it should be adjusted.
09-01-2015 08:16 PM
