need help soon!
need help soon!
well i was drivin down the road tonight and someone was drivin behind me, and they told me that my wheel was wobbling on the passenger side rear.....what would cause this...is it the axle bearings or what?.....would i have to buy axles and everything to fix it? ive been thinkin bout upgrading rearend and axles? where coudl i get them at and what is the best to buy?
RE: need help soon!
I dont know jack about rear ends or axles, but that sounds like it would suck to be you. If you have to replace it, be sure to beef it up alittle and buy the best stuff. Sorry bout your luck, hopefully you wont have to spend alot.
RE: need help soon!
First look to see whether the wheel is bent or if it's actually an axle problem.Put the rear end up on jackstands and with the car in gear spim the tires.If you have a bent rim these can be felt inside the car while your driving it.
