When lowering, at what point do you have to worry about the physics of the suspension as a whole, steering, ground clearance, or bottoming out over bumps?
I'm also curious about height, and the effects of that on the steering. I'm gusiing you need an alignment immediately after installing the springs, but if the ride height is altered will the specs for alignment be affected by that?
