IAC Valve problems
IAC Valve problems
Hey guys, I've been having a problem with mine. I pulled the codes but didn't get anything. I ordered the IAC valve because I can't find anything else wrong with it. I got in online from Autozone for ONLY 55 Dollars!!!!!!! I'll let you know if it fixes the problem.
IAC Valve problems
Usually when there is a problem with the IAC, the SES light will come on, and give you a code...(I don't remember the numbers) but you should actually get 2 codes. Left and Right bank too lean. </P>
Something like that. $55 is like a sore dick. You can't beat it. Might as well replace it.</P>
</P>
</P>
IAC Valve problems
Originally Posted by 97FordGT
yeah but since i already have a check engine light from the off road h then would it still throw those codes out
</P>
hey man, you better get MIL eliminators since you have an off road pipe............</P>
IAC Valve problems
yeah i know i need to get mil eliminators i put the new iac valve on yesterday and the car will idle now but it has a real bad lope like i have a cam or something and the rpms will hang for 3 or 4 seconds. i can still hear air sucking from somewhere. is it possible that the seal in between the throttle body and the intake is bad. that is the only thing we can figure out
