01 GT Brake Problem
RE: 01 GT Brake Problem
I have the same problem with my '02 GT 5 speed. It started when it was driven to Indiana during the bad storm last year, Jan. 2005. I have changed all 4 calipers, all 4 rotors, front / rear pads, new hubs in front. It has had a abs system check on machine, complete brake system fluid replacement, tires balanced rotated 3 times, front end alignment, rear diff fluid change w/additive, trans fluid checked.
I have heard just about everything from brakes, bad calipers, alignment, hubs dry. I had the exact same problem with a Pontiac Firebird. I finally changed the struts to fix the problem. I have attempted to get the struts changed by 3 different shops, which is covered under my extended warranty. Everyone says they check good. Bounce check/visual check. I think the problem is in the struts, or possibly dry ball joints. But, no mechanic will change the latter 2 for me, so for now I am stuck with a noise/brake grinding feel that is driving me nuts and has lasted a year. It will be there, until I change them out myself. Best of Luck...
Tap
Tap
I had a Pontiac Firebird with abot 42k miles on it, when the same problem you are having occured. I did full brakes, tires, balance, rotate, with no fix. The struts were finally changed out by a local mechanic, and it fixed the grinding feel/brake noise.
As far as my '02 GT, I have tried everything but swapping struts and ball joints. three separate dealers and one Master Mechanic (specializes in Stangs) say the struts aren't bad. So, I haven't had luck with getting them changed out. When I get some down time from work, I will swap the struts out myself. I currently have 45k miles on my GT.
Tap
Tap
I had my mechanic drive my car and he said the problem was my ABS system. He said that I just had to live with it because he couldnt change it unless Ford had a recall on it.
Did he put it on the ABS test machine, or just tell you that, because he couldn't figure it out. I had my ABS sytem checked by computer. The pressure test checked good. It cost $135, but it was piece of mind. I changed all four calipers, and had a complete brake system flush and check. Mine was all good.
Tap
Tap
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
