front springs
front springs
im considering installing some diff front springs to raise my front end up a little. im thinking sportline or h&r, any suggestions. also the rear springs are progressive saleens will it make a difference if the front and rear springs aren't the same brand. i think eibach makes the saleen springs.
RE: front springs
I'm confused... Do you have lowering springs now and the front is too low? Or do you just wanna jack up the front from stock (I pray this sint what you are saying). Sorry, but I'm a little slow, so I don't get what your situation is...
RE: front springs
That's probably your best bet. If you still have your stock springs though, I would suggest you cut those and put them in and see how you like that first. Typically it's usually considered just a good idea to replace all the springs instead of just one or two, but I guess if you are doing both front and/or rear and not just passenger or driver's side, it would be fine. only thing with cutting your stock springs, besides being able to personally adjust the ride height to your preference, is that it's gonna be stiff as hell. I would suggest the sportlines, but Cutting and testing your stockers won't hurt anything, and if you like it, it might save you 240 bucks
RE: front springs
ORIGINAL: Emann0007
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
