Convertable top lloose
The top on the driver side of the car keeps working itself loose. When i bought the car about a year ago i tightened the hook up. Now it is 1/2-5/8's from touching the rubber seal. I think it could have to do with the hook because when i push the handle back in to lock the top down and in place if i leave it about an inch or so stucking out (not fluch with the trim) it seals. Has anyone had this problem or know anything about the latch mechonism?
RE: Convertable top lloose
I had just the opposite problem when I replaced my top. It was so damned tight I literally had to hold onto each clasp one at a time and use all of my 170lbs to pull it down to close it. Eventually it loosened up... Now it's nice and tight but still easy to open/close. Sounds like maybe the threads on your clip have stripped out....
not sure i understand your complaint, but the driver side hook for my top was loose. i noticed that it was adjustable. i removed the little lock screw for the hook and turned the hook clockwise to the correct length and now it's cool.
maybe you can take a pic of your problem and post it.
I already loosened the hex head screw that holds the hook in place and tightened the hook. Now the top is loose again. When i push the handle in to where it should be there is a half inch gap that you can feel the air rushing through. With the handle pulled out 3/4-1" it stays shut and air does not leak. Its more of a cosmetic thing than anything else but i like to have the car as close to mint as possible.
treesloth
09-28-2015 07:03 AM
